How can I tell what voltage a PPS steering rack sees at highway speeds?
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
Not that simple. Current controlled proportioning valve. That said, to answer your question, the PPS solenoid is normally closed and opens when normal polarity is applied to the + and - terminals. Although the book doesn't say it, under those conditions displacement of the needle will be appx .80 inch. Again though, if current isn't limited the coil will fail in short order...
