H
HmongSupra said:I need to know how to tell if my pistons rings are fried.
MKIIIChucky said:Compression test it , its a guage with a fitting on it u plug into where your sparkplugs go , test each cylnder n write down what each cylnder psi level is , make sure u have some1 with u , it makes it a little easier ! if your in the 160 to 170 psi level your good if under 145psi its startin to lose compression, witch usualy is the rings! .late.
MKIIIChuckY
lagged said:err yeah um.....just do it the way the TSRM says.
there are also methods to determine if the rings, or valve seals are bad.
lets say you havelow compression on one cylinder, put an ounce of oil in the cylinder and test it again, if the compression rose, its the rings, if it stayed the same, its the valves.
