How can i Remove ABS System.
empera
Authorized Vendor
Philly.
ok where do i start with this? My ABS system isnt working now so i decided to remove the whole thing, wat or how should i do this? How do i stop from fluid to get everywhere, i dont want to leak the system and die from not being able to stop.
Any advice would be greatly appreciated.
Thank You.
socc924
CT and Philly
Or, why not fix the ABS?
Oh man, the crazy ideas that are thrown around here. lol.
anyway... if you let me know what lines I would have to grab and its not to complicated I could try to get them this weekend if i have some extra time.
socc924
CT and Philly
His abs system is already not working, so he has no abs. He wants to remove the abs components.... probably because he is insanely jealous of my 86.5 w/o abs. Is the only difference in the system the hard lines that are between the abs unit and the master cylindar?
mkIIIman089
Ohio
Already checked it out for my own purpose. Here's what you need for a complete conversion from what I could see in the parts diagram.
-#4 front brake tube 47314-14141
-#2 front brake tube 47312-14160
-#2 front brake tube 47322-14230
-#3 front brake tube 47313-14222
-clip 90461-06055
-brake tube clamp 47371-30010
-non ABS brake master cylinder 47201-14560
Jeff Lange
Administrator
4,926
Sunnyvale, CA
jefflange.ca
List Prices (USD) for those parts:
$11.46 - #4 front brake tube 47314-14141
$9.49 - #2 front brake tube 47312-14160
$17.09 - #2 front brake tube 47322-14230
$21.75 - #3 front brake tube 47313-14222
$3.33 - clip 90461-06055
$12.66 - brake tube clamp 47371-30010
$142.47 - non ABS brake master cylinder 47201-14560
mkIIIman089
Ohio
Prices from Curt ;) which I managed to forget I had.
-#4 front brake tube 47314-14141 - 8.47
-#2 front brake tube 47312-14160 - 7.01
-#2 front brake tube 47322-14230 - 12.63
-#3 front brake tube 47313-14222 - 16.09
-clip 90461-06055 - 2.46
-brake tube clamp 47371-30010 - 9.39
-non ABS brake master cylinder 47201-14560 (changed it to 730 from 560, assuming they do not make 560 any more) - 175.10
