I recently changed all my rotors and pads in order to pass inspection.
After driving it for a bit I noticed there was a bad smell, like brake pads were dragging. The guy at the inspection told me to check my calipers because the pads were sticking. I go for a highway drive to see how she drives and upon returning home my step dad and I looked around the car to figure out where the smell was coming from. We touched the front right wheel and it was too hot to touch, you couldn't hold your hand on it it was so hot.
We pulled the wheel off when it cooled down and on the rotor you could notice the pad was dragging on it.
What can I do to fix the caliper? Do I need a new one? What is wrong?
Also, the center of the hub was very hot too, is it possible the wheel bearings are dead or need more grease? Will the heat wreck the rotors?
We are checking it out in 2 weekends but I need to know ASAP.
Also, should I avoid driving the car until it's fixed?
Thanks
Thanks
