Hot engine.. please help
maddanny
bucharest
Hi guys, I have a jza80 2jz-ge from 1993/07 supra.
Problem is that the water temperature rises to red.. not leaking anywhere... exhaust only. I think is the head gasket.. and I want to replace it but I don`t know the size.
I`m from Romania and in all country are 3-5 supras.. and at the pats store the don`t have supra mkiv n/a in the program list.
Please help with size of head gasket or a part code.
Thanks
Backlash2032
1,823
Nebraska
Think of other cars that would have a 2jz-ge. GS300 and SC300 are the two that pop up right away in my head..
And actually the ge and gte headgaskets should be the same.
veedubin
Official SM Decals
GE and GTE are same shape, but GTE is a thicker gasket. It will however help lower your compression ratio if you want to boost the GE....
