Hose from throttle body..
scotty
476
Norway
scottnicholas.net
Hey,
Where does the hose from underneath the throttle body go? I'ts quite a long hose. Can't find anywhere it's supposed to go..
Thanks,
Scott
PHILLYSUPRA
serious
Jun 29, 2005
99
philly
im assuming your talking about the coolant return hose. on your tbody the one that points downward goes back to the little coolant return pipe that goes all the way back around the block. look carefully under the lower intake manifold section and it is going to be sticking up.
7M-KDL
Seeking high numbers
cant you bypass that hose anyway?
