Hose barb
arknotts
formerly ark86
Jan 9, 2008
461
Ohio
^^ +1. I wouldn't feel safe using a hose barb on a part that--if it fails--would turn your engine into toast ;)
mecevans
1,295
M-bay, cali
there rated for hydralics which run at higher pressures though. the only thing about an oil cooler setup that really expensive is these damn hoses barb fittings. 12.99 each!:aigo:
joel903
314
Conover,NC
I doubt those fittings will fail, they'll probably hold up the entire life of your motor. Just make sure to either use brand new rubber hoses or best if you just use silicone braided hoses on it.
89nasupra
Sugar, Water, Purple
Apr 8, 2008
501
Lafayette, Louisiana, United States
you can find the same thing at Lowes or Home Depot. that's what i used and no problems so far. only that happen is a i had a clamp fail on the pressure side that dumped about all my oil. a good hose barb will do you no good if you have cheap hose clamps.
