Horn not working after installing hub and steering wheel
hellremix
Pasadena
I recently installed an nrg hub and nrg quick release, but for some reason i couldn't find the horn wiring, it worked before with my old steering wheel, but after installing the new stuff my horn doesn't work anymore. does anyone have any suggestions or solutions?
Thanks
airhead04
1,489
Lima, Ohio, United States
Soooo, you undid the old steering wheel, and the wiring wasnt there? Im not understanding how you couldnt find the wiring. it should have been right there. lol
And with a quick release, I dont believe you can have a horn on the steering wheel, because then the wiring would hold it to the steering colum.
PureDrifter
VIP Cruisin'...
Aug 11, 2009
317
CA
www.clublexus.com
any good quick release should have contacts that complete the circuit whenever the wheel is inserted. it should work fine provided you can find the one wire for the horn trigger (as i recall, on toyotas of this vintage but not specifically on my supra...yet) the horn has a single wire trigger that activates the horn when grounded to the steering column/chassis ground.
hellremix
Pasadena
so what color was your car horn wire? and my quick release is nrg.
---------- Post added at 06:00 PM ---------- Previous post was at 05:55 PM ----------
the yellow wire is for the airbag, and i have a prong with multiple wires on it that plugs into the stock steering wheel. im guessing the horn wire is in there. im just wondering what color the horn wire is.
---------- Post added at 06:05 PM ---------- Previous post was at 06:00 PM ----------
not the prong the harness with multiple wires
blackie87t
st. louis
what i did on mine is just wire up a whole new horn. just go to autozone or advanced autoparts and buy a universal horn. run the wiring thru the fire wall to inside your cabin area and use a push button to activate the horn. it was cheap easy and when installed properly really clean looking inside the cabin area. thats just my 2 cents
^Kinda defeats the purpose almost of having the button.
I could see it working with a quick release kinda how you dont have a wire wrapping around the column like stock but idk for sure.
Oct 11, 2005
3,816
Thousand Oaks, CA
The horn wire is blue-red on most cars, but I'm not sure about 90+ with air bag. Grounding it sounds the horn. I can't imagine how wiring a new horn in could be easier than tapping into the existing wire, but to each his own I guess.
Chambers
Now you know
Sep 9, 2007
981
Baltimore County, Maryland
The MOMO hub I have has a contact surface for the horn circuit, its copper I believe. It is as the base of the hub facing the front of the car, I had to make a small tab and mount it utilizing one of the misc unused screws for the round slider since it was gone there were a few places to mount it. The tab contacts the surface on the hub and the wire from the harness for the horn. From there a pig tail with a spade connector built in to the hub connects to the button and the button grounds to the wheel-hub-steering column-body.
hellremix
Pasadena
Thanks guys. I decided to buy a new horn, but for the wiring I'm figuring that out when i have the time. but the tips are very helpful
