hood struts
undrpress
gresham ,oregon
didnt spend alot of time looking but, was wondering does anyone happen to have information regarding brand/part # for gas struts for the hood (weaker ones) on a mk3 using a composite hood. Want to use a factory type strut/latch set up not hood pins. I do realize I may end up having to use a prop rod set up for the hood. but would prefer to keep the install cleaner (more factory like) any information would be awesome thanks patric.
Suprapowaz!(2)
2,870
San Antonio, Tx.
I've always wondered if a pair of worn out stock hood struts would work for guys with lighter hoods. You just have to be careful because they still might have enough umph in them to bow your hood while it's closed. I have a pair that wouldn't support my stock hood. Maybe they'd work for you. If you're interested PM me.
Silver MK3
1,517
Madison, AL
This is what I was going to suggest. I think I've seen people do this before for carbon fiber hoods.
Can take some blown ones. Drill a hole in the piston and put a pin through it so I cannot lower.
