So sometimes on the 1990 Honda Prelude 2.0, I crank it and it starts, but the idle just goes from 2,000 to 1,500 to dead in about three seconds. Then I wait a while and it starts without it dying like that. What would I be looking at?
csr ma71 said:So sometimes on the 1990 Honda Prelude 2.0, I crank it and it starts, but the idle just goes from 2,000 to 1,500 to dead in about three seconds. Then I wait a while and it starts without it dying like that. What would I be looking at?
MDCmotorsports said:For your serious reply...
Sounds to me like a fuel issue as in you are running out of fuel.
Check the pump and fuel filter for flow.
lankytheseriousmonster189 said:but honestly..i'm not sure...is the AFM/MAP/Weedeater carb. in good shape?
what about the CSI or cold start system in general?
lanky189 said:well first leave the hood closed.... stand in front of the car... locate that small box on the hood...inside that box is the letter "H" ...there's your problem
csr ma71 said:You don't see me smacking the CD player out of your hand and tell you to go get an Ipod.
Ok, MAP and fuel. Will check it out later.
