Hey all!
No i become member in here so i can show you what i am building!
First off all...my english aint that good ...so have patience
My car is an Toyota Celica Supra from 1984!
I have totally restaureted an 5mge with a 7mgte crank/rods!
Then it is identical with the 6mge!
Here is the setup as it is know!
285 degrees cams 1.3mm higher lift! (reground stock)!
Cam houses shortened 1.3mm in heights!
Aem adjustable camgears!
Ported and polished top and valves!
7mgte Crank and rods (increase the volume from 2.8 to 3.0 in a std 5m block!
I hav calculated that the compression is raised to about 10.1:1!
Crank, Flywheel, Pulley, Clutch, are 100% balanced to 10000 rpm +!
Complete engine gaskets set, new rings, new main and rod bearings....all is new in the engine!
Special ignition wire( cant remember the name)!
Electromotive Tec 3r Engine managment system including new sensors. Tps, mat, map, ego...etc!!
(http://www.electromotive-inc.com/)
Homemade Throttlebodies wit 12 295(7mge) injectors!
Std tb size is 60mm.....Now it has 6x50mm intake!
Pacesetter manifold...and 2½" pipe the rest off the way!
Servo sterring is removed......aircon is removed....the engine only have to pull the generator and the water pump!
Only to seats in the car and a dashboard...that is all there is left !!
Here is some pic of my little project!
......to be continued
