Hey all.
Because of my dreams of a high reving NA engine, i had to either buy og build a new and ligther flywheel.
Also i had to find a stronger clutch so here is what happend.
I made some drawing of the flywheel, and using the solidworks 2008 program i also could calculate the weight of it .
The flywheel is made of steel 52, strong steel that is used for that kind of things.
And then the cnc machine was started .
The clutch is a tilton racing clutch with to cinter metallic plates, and it can handle up to 950nm.....so i think it will do
Here is some pic
Host Images with PicTiger
The flywheel incl the clutch is heavy standard.....17kg
This new one incl all.. 8.6kg
I think it will rev fast
Of course i will loose some of my tourque.....but i build for high rpm so f.ck that
Here is some pic
