holy fu#k HELP
j breckles
mission bc
I pulled the motor and trans together. I fixed the engine then bolted them back together. Then houst it in and get within 1 inch of the mounts and thats it.What's the proper way to put back in? Is there a trick somewhere. thanks
Devin LeBlanc
1,830
Las Vegas NV.
j breckles;1780063 said:
got 92 7m built got 88 car standard r154 used of v8s but this takes the cake did every thing right i think changed the mount brackes,motormounts,checked the pan its the same i checked over and over im instaling tranymotor together got all the right moves but that last inch cant get it spent 4hours ? how you install you r motors?the mounts on or off or on the frame or what there is no more room what? there on backwards no i checked you cant screw that up on this 88 help:cry:this is a nightmere instal without the pan tomorrow maybe finaly line up the mounts thanks
woah, There are a bunch of scrambled words here. I can't read them....
bioskyline
1,236
powell river bc
sounds like you got the wrong mounts. the 86.5-88 used a different mount than the 89-92 7ms. was a subframe revision to make the 1jz fit better. you will need to use mounts from the car its going into.
barkz
363
Afghanistan
wtf did you just say?
supraguy@aol
Well-Known Member
Dec 30, 2005
4,239
Atlanta
I think you're overthinking this-
He said(I think!) that he pulled the engine out, repaired it, and put it back in, no swap or anything.
It's easier if the mounts are on the motor, and not on the engine cradle, when you lower it in.
Supracentral
10
Ok folks, this is the tech section, a couple of comments:
1. To the OP: I see you edited your initial post so it makes a little more sense, good. The quality of the question often drives the quality of the responses.
2. To everyone else: While the problem may seem obvious/silly to you, it's obvious the OP is having difficulty, if you're not willing to help, don't post. No more wiseass comments please.
IBoughtASupra
4,455
Queens, NY
Jack up the transmission and push the engine back toward the firewall. It will slip in the grove.
Take a picture of the mounts and post it so we can make sure those are the right mounts for your car.
