Specs:
Good compression and leak down test results.
I have fitted a wh1c Holset after the stock turbo failed. I built the whole setup for under the price of a rebuild.
4 inch intake, full flow exhaust, driftmotion front mount intercooler, upgraded radiator, 38mm external wastegate. I have a innovate wide band, but nothing to correct fuel or timing.
The car has a stock fuel pump, with 440cc injectors and a stock maf. I understand that this isn't the ideal fuel system, and larger is needed to run the turbo properly.
The car runs very well, and on a test run it settles at around 10-11 psi, and hits fuel cut around 12psi. Is it safe to run the car under fuel cut? I purchased a 5 psi wastegate spring to lower the pressure to hopefully about 6-7 psi. I would like to tune the car at very low boost and increase later down the road.
Are safc's junk? Is it a waste of time and money buying a piggyback. I was interested in maft pro but don't have the time to keep updating and messing with new versions. If a standalone is required to tune correctly I will save my pennies.
I suppose my real question is can I run the Holset on stock fuel system @ low boost tuned and be safe.
