hks vpc issuse
88supraTT
292
around the bend
I installed a hks vpc in a 89 supra, and when I did,I checked to make sure it worked before i installed the rest of the dash. When I checked it, the car was takin apart, it lite up when the key was in the on position. After installing the dash, it doesn't turn on when the key is in the on position, but when i turn the key back to the off position then it lights up and stays on.
Note: i don't have the check engine light.
I also can't start the car because the engine is not ready to be started yet.
ask questions if you need more info, I really need to get this problem fixed, I'm pretty sure its something simple.
SevenMKIII
No more Supra no more fun
Jan 13, 2007
474
Central IL
Did you install it with a field harness or tap into the harness? Shouldn't have tapped any ground if you use a field harness.
88supraTT
292
around the bend
I'll go over the wiring again and make sure. All you do is plug the hks harness into the factory harness there is no splicing or cutting of wires. Maybe the harness came loose, I'll check tomorrow.
