HKS VBC problems!!!! Please help
V
V8kller
Guest
I just hooked up my hks vbc and it doesnt work. :aigo: I cant adjust boost at all. I Called up HKS and they said that i have it hooked up right, does anyone have any suggestions if so it would be greatly appreciated.
boost fiend
852
Rockford, Il
what kind is it(e.g. evc IV V etc.). you might have a problem in the wiring harness for it or have vacume hose issues(backwords, not big enuf/too small). double check all the settings too. did you go through all the setup testing stuff first so it can learn your boost curve?
V
V8kller
Guest
It is actually a mechanical boost controller. and i checked for leaks and for kinks but there were none. Im starting to think that it may be a faulty valve.
V
V8kller
Guest
No the car boosted just fine and had no vacuum leaks. i cant figure out unless the valve itself is bad.
