HKS MHG 2.0MM STOPPER
87_supra
7
Bakersfield, ca
Im planning on getting a HKS stopper 2mm HG. I know it will lower the compression but will it mess with the timing or any other thing? Any other info on this MHG would be appreciated.
supra90turbo
shaeff is FTMFW!
MA, 01440
Depending on how much material has been removed from the head or block, we can't accurately answer that.
If it doesn't quite compensate, or overcompensate for material removed, it wouldn't hurt to degree the cams. Not a necessity by any means, but it'd be good.
suprarich
Guest
Nov 9, 2005
2,187
ohio
It will do nothing to the timming. The only thing it will lower is the compression like you mentioned, and the amount of money n your wallet. I don't know what your goals are with your motor, but there are several other gaskets that are much cheaper and willl do a fine job.
supra90turbo
shaeff is FTMFW!
MA, 01440
It sure will alter the timing if the gasket doesn't make up for any material removed from the deck, and head surface, or if the gasket overcompensates for such.
suprarich
Guest
Nov 9, 2005
2,187
ohio
I am not sure I understand how the the thickness of the gasket will alter the timming. Weather the head was milled or not. All the timming is in the head, both ignition, and cam timming, and I don't thing it knows weather it is an extra 10mm above the head or and extra .5 mm above the head. Maybe I am missing something.
The gasket thickness will change the distance from drive pully to driven so does affect the timing.
To degree my Cams in using a 3mm MHG I needed to set them to 4 degrees retarded but with a 2mm MHG they end up around 1 degree.
