hks fuel cut defencer
Dunckel
2,949
Spokane, WA
Did you ask the previous owner?? It can't be that hard to find. Look behind/in the glove box, or under the steering wheel under the cover. You'll find it. Do you know what it looks like??
Dunckel
2,949
Spokane, WA
Yeah, it shouldn't be that hard to find. (if it is there) Maybe call the previous owner and ask him to point it out. Maybe there is a way to check if you actually have one. Like maybe force the car to hit fuel cut once or twice. It should be around 10-12 psi. I might be wrong on those numbers for sure though. There might be a safer way to check through the diagnostic block. I dunno. Maybe I use the word maybe too often.
