Ive got one in my for sale threadJspec7m88 said:Well if any of you Lex AFM users are going MAFT(PRO)...I need to buy a Lex because maxing out your stock AFM w/ no boost controller sucks.^Nice numbers, fellas.
NashMan said:and what might that be i am tryihng todo this on pump as well with 580 injectors
GotTurbos? said:well basically I have a small throttle body on my intake that is powered by a wastegate actuator that opens under high boost, sneaking air past the afm, It has been deemed "the cheater valve"
MDCmotorsports said:Also known as the "Lean the mixture way the F@#k out valve."
