What the highest horsepower achieved with a 7MGE. Preferrably dyno proven and engine only. I'm wanting to build another GE since I bought another Supra and already have a GTE engine.
Good luck, I did mine and with a lot of money, you have to have a plan and be happy with what you got. Click on my signature and read the list, it's quite long. 215 and 207 at the rear wheelssupra_kid101;1079673 said:What the highest horsepower achieved with a 7MGE. Preferrably dyno proven and engine only. I'm wanting to build another GE since I bought another Supra and already have a GTE engine.
AJ'S 88NA;1079695 said:Good luck, I did mine and with a lot of money, you have to have a plan and be happy with what you got. Click on my signature and read the list, it's quite long. 215 and 207 at the rear wheels
AJ's Public Profile / About me said:About AJ'S 88NA
Location
tenn.
Home Country
United States
Model Year
1988 (MKIII)
Engine
7MGE (N/A)
Transmission
W58 (5 Speed)
Mods
97.5mm flycut balanced stroker crank
Wesico .060 over 10.5 to 1 comp.
plasma rings
Balanced Eagle H beam rods
Clevite 77 bearings
ARP rod bolts
ARP head studs
ARP main studs
HKS metal HG
Toga HV oilpump shimmed 5mm
2" added depth oil pan
Stage I ported head
Supertech .05 oversized valves
3 angle valve job
Ferrea dual springs
Titanium retainers
Web cams .322 lift & .218 dur.@50 deg.
RC 550 Injectors
Holly Fuel Pump
AEM Fuel pressure regulator
Pacesetter Headers
Maft-Pro w/speed density setup
LM-1 Wideband
Eibach Pro springs
KYB Struts
Motegi 17" racing wheels
Owned Generations
MKIII
CRE;1082137 said:I'm telling you AJ... those 550's have got to go... Then there are the wiring changes, but we'll cover that separately.
Yeah, yeah. Got some 440's laying around ?CRE;1082137 said:I'm telling you AJ... those 550's have got to go... Then there are the wiring changes, but we'll cover that separately.
CRE;1082229 said:Hehe.... talk about a thread hijack. :icon_razz
Alex, remind me what pressure you're running? I wouldn't run less than mid 30's with most injectors... but I don't know as much as IJ.
Personally, for a 200 to 250 RWHP car I wouldn't expect to run anything bigger than ~360. 440's would be a step in the right direction, but I'd get them cleaned and flow tested first... hell I've got three full sets here. Hey Alex, you pay send all four sets in for cleaning and testing and I'll give you a matched set to run. :naughty:
And YES, wiring changes... and YES, I DO like to watch you squirm! :evil2:
Newer cars are a little more advanced, and you're compairing a turbo to a non-turbo.casperfast;1087913 said:so why is the 7m ge soo weak? i thought that it had alot of torque? i also have a 95 talon tsi awd turbo. i have an evo 16g fmic and 1150cc injectors and im putting down 412hp and 318 tq on 18 psi. my supra is fast but it doesnt have near as much power as the 4g63 4 banger. does the turbo make that huge of a difference?
