High RPM power loss and codes 14,22 & 32 advice needed.
sleepersupra
i hate this car
Nov 5, 2005
311
Broken Arrow, Ok
ok i looked up what these mean and i came up with...
14-ignition signal...
22-water temp sensor signal
32-HAC sensor signal
my question is will any of these cause the car to run like crap from about 4,000-5,500 and be fine the rest of the time?
Supracentral
10
Any and all of them could cause it.
The most likely pair are:
14 = bad ignition - can't run well at high rpm with bad spark.
32 = High Altitude Compensation - adjusts several engine operating parameters to compensate for low density air at high altitude.
However, you shouldn't be driving the car hard if it's got codes. Get the engine management fixed before you blow the poor thing up.
PS - edited your thread title to help attract more help - read this: http://www.supramania.com/forums/showthread.php?p=230560
