As far as I know, you can get about 230-250hp, but only if you fit the GE with a modded bolt-on turbo setup. Anyway, I don't think it would be worth it to mod your 7MGE because:MKIII N00b said:whats the most anyone got out of an NA? like the most. let me know so i dont have to go turbo.
Jervis Mcstabby said:1. You can't upgrade it
2. You can't have more than 12psi of boost, as the GE has a higher internal pressure than the GTE. So if you tried to go over 12 your engine would likely explode.
