Oil in your accodian intake pipe is normal. (Your valve cover vents go into the accordian pipe, and this draws off any blowby gases, and oil vapor that comes out the valve covers.)
The idea is to burn off those hydrocarbons by routing them to the intake again.
The down side is that the hydrocarbons condense on your intercooler, and you get a thin coating of oil in your intake, IC and IC pipes as a result.
The upside is that by putting a vacume source on your motor, it makes it easy for the oil to drain out of the turbo back into the oil pan where it can be used again to lubricate your motor. (After the foam goes away. The oil that drains off turbochargers being used at high boost pressures is very frothy. It's just been churned up by a shaft spinning somewhere between 70,000 and 150,000 rpm.)
This "froth" is why the larger drain is needed, and if your engine is not vented well, or builds up excessive blow by pressure in the crank case, it will cause the "froth" to build up and oil then can get around the piston ring seals, and out your exhaust...causing the smoke..
Running your motor with a good vacume on the crankcase actually adds horsepower. (Drag motors run converted pumps to create extra vacume on the crankcase, and that adds up to more power than what is needed to run the pump off a fanbelt actually.)
For our turbo motors, a good catch can between your valve covers and the intake will condense some of the oil vapor, so your drawing less oil vapor into the intake, and coating your turbo, pipes and FMIC with less oil as well, but still have the advantage of drawing off excess pressure from the crank case by simply routing it to the intake pre turbo.
