High Idle
xXxICExXx
366
Abbotsford, BC, Canada
For the past couple weeks my idle has been way too high, pretty much 1500 in park and 1000 in drive. I have no idea what it could be I have been working on so much lately with the engine. After while it seems to kick down only after about 20-30 minutes of running and AFTER it gets shut off. The only thing that I can think of that could be related to this problem is my charcoal cannister removal, it was done on the same day this problem started occuring. Help would be VERY appreciated please :icon_bigg
antman
632
TN
listen to shaeff and MDC. they have alot of knowledge. always attack the problem not the symptom.
xXxICExXx
366
I did the code test and I did get code 51, still cant for the life of me see why its still doing that though. I just took the supra for a spin now its idling too LOW, and keeps stalling out almost everytime i come to a stop. I litterally didnt do anything, except push the purge hose another 1/8 inch in for a more secure connection. :icon_conf Need help:cry:
xXxICExXx
366
UPDATE:
I started fiddling around with everything i could see and I finally am back to a clean sheet with the diagnostic codes. The idle is still a bit low but its not stalling out at all anymore, so i must have done something right. Now all i gotta do is adjust the idle back to normal and im set.
