high compresion numbers, whats wrong?
lifted
157
memphis
i did a compresion test today, i got in between 180 and 190 on all cylinders.i did it without turning of the fuel so i was thinking maybe this is why the numbers are so high. the engine only has 30 to 40 k on it. when i was putting the mhg on the rings looked fine and the cylinder walls were not scared. any ideas why the numbers are so high?
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
When you did the HG did you clean out any carbon buildup? If the car was still pumping in fuel that'd probably account for a fair amount of the increase, how much I don't know. Do you know how much material of the head and block was shaved off?
lifted
157
memphis
i saw the cylinder walls 1k ago, i wiped one with my finger and all the stuff came off. so there wasnt much build up at all. i am starting to think they took alot more off my head then they told me.
