Hey guys, I recently did a HID projector retrofit into my Supra. Link to that project(http://www.supramania.com/forums/showthread.php?187113-Some-Questions-on-Doing-HIDs-the-Right-Way). Everything works great except for two things. The first thing is that the high beam indicator on the dash no longer comes on when I turn the high beams on.
My other issue has to do with my fog lights and high beams. When I have both the fog lights and headlights on and then turn on the high beams the high beams are stuck on until I turn off the fog lights.
I'm not sure what the problem is or how to solve it and was hoping someone here would know how to. I'm not all that worried about the high beam indicator because it is really easy to tell when they are on, but if it is a simple fix it would be nice to have the indicator function. I assume it has something to do with not having a real bulb plugged into the car harness and instead just the relay harness plugged into the driver's side and nothing on the passenger side.
Any input is appreciated.
Thanks!
Thanks!
