Guyana00 said:I also think you should tuck them in the wiring loom, because like mentioned before, problems can occur. There are problems that can occur you may not have even realised could happen until it does. Then after hiding the wires so well you're gonna have to after them to fix the problem. With the wires just "hidden" in the wiring loom then you would still have easy access to them when you want to upgrade, or fix something.
Poodles said:meh, looks like a troubleshooting NIGHTMARE if something shorts...
