HID question (help)
lost_breed
14
DENVER, PA
O.k this might be a dumb or easy question,but forgive me. I had HID on my MR2 turbo and went ahead and did the swap of the HID headlight over to my Supra. Everything is hooked up right, i know because it worked fine on my MR2. Well, when i turn it on it just flickers for about 30 second than it turns off. Any idea?
Again, sorry for the question.
shaeff
Kurt is FTMFW x2!!!!
10
Around
Or the stock wiring is crap, and you need to run a dedicated power harness. HID's draw much more on start-up, sometimes up to 7-8 amps. That's just too much for the stock wiring, especially with how old it is.
Make your own power harness using a relay.
sneakypete
Regular Member
Jul 18, 2007
1,129
Central NJ
i had the same problem with my first HID kit.. and it had its own harness. turned out the ground wasnt good. so i rewired it all. then a ballast blew.
if your interested. i am selling my old HID wiring harness (comes with relay, fuses and bulbs)... just no ballasts.
pm me if your interested
