Hi guys, im wondering about the HG thickness i need, i asked my machinist to measure the Head and Block, however i think he may have gotten the Block height wrong, as its bigger than the 198.5mm spec. However the head height came to be 115.443mm so i know im already looking at a 1.8mm thickness just from that alone. So im wondering if the minimum was taken off the block can it be safe to say a 2.0mm MHG will work just fine. My block was also bored out .020 over and i was also wondering if the Titan MS MHG had a HG bore size bigger than 83mm.
Thanks for taking your time to read this.
~Sside
~Sside
