Hg selection question?
mk3713
Up for sale
Nov 29, 2005
97
Houston
I searched on these threads but i might have missed something. My question is what headgasket to use. I whant to use the Titan one but i need a different size. I dont know which one though the 86mm or 84mm. From searching i know stock bore diameter is 83 mm i am over boring .040 or 1mm. I think i have to use the 84mm gasket but i can't find it. Do i have to get it custom made or does anyone know where i can find one? Any help is appreciated.
mk3forme
Lexington KY
amazing. Im searching for answers to the same question. Any help from you pros would be greatly appreciated. I saw where defiant bored to 86 mm but I also think he had his block coated for heat. What is the max safe bore to get out of this block?
suprarich
Guest
Nov 9, 2005
2,187
ohio
IJ. said:
84mm bore and an 84mm MHG I'd be a little concerned about heating the edge of the gasket if the dowels aren't exactly right.....
The Titan is an 86 mm HG just like the HKS.
mk3713
Up for sale
Nov 29, 2005
97
Houston
Thanks guys i guess i got my answer. I will go with the 86mmTitan gasket. I went with the HKs bead type before and blew it.
mk3713
Up for sale
Nov 29, 2005
97
Houston
I must admit it i did reuse the gasket on my second engine. Was not worth reusing. I think thats the reason it blew.
