Hey Everyone
Sideways82
4
Cali
Got a message saying i should introduce myself. My name is John I own an 82 toyota celicasupra. I've had the car a few years been doing mods and tracking the car. It currently has a blown 7mgte in it and I am building a 7mge to replace it for the time being. I am using this forum to resource some parts and knownledge from reading your posts. The 7mge is going to be 10.5:1 compression pistons blue printed and blanced bottom end brain crower 272 cams, 70mm throttle body, 295 (yellow tops flowed at 310 when cleaned) injectors, Haltech E8 standalone, and will be spraying alchole/nitro as an additive, doug thourley headers modded to three inch back. Still have some work to do will post up pictures soon. Also any one have a couple of 295 yellow tops two of them failed need to get a couple. Here are some of my videos with the original 5m.
http://www.youtube.com/watch?v=L0w_gfkzZps
after two months
http://www.youtube.com/watch?v=92lzr9B33tU
bigger balcony
http://www.youtube.com/watch?v=rRBdFjhQlXQ
button willow
http://www.youtube.com/watch?v=zeSgjPZgoYU
mkiiichip
1,434
WI
Your damn good, i enjoyed your vids.
Are you running a two piece driveshaft and stock lsd?
Sideways82
4
Cali
One peice drive shaft stock LSD shimmed up. Pulled the LSD apart and put in some brass shim stock behind the clutch plates makes it lock just a little faster.
