help
bridg3r
50
Holland,MI
is the wireing harness ran obove the intake manifold or below and does it matter if the injector wirers are mixed up thanks
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
Cripes, this is not the way to get the attention you want. Use a descriptive title, for crying out loud. Proper sentence structure, capitalization, etc, wouldn't hurt either.
The wiring harness goes above the lower intake manifold and below the upper intake plenum.
And themadhatter is correct.
87mgte
87 Turbo Targa
Sep 9, 2007
536
Sequim
sneakypete;972287 said:
they go in order from 6-1 if you start at the end of the harness at the back of the motor.
lol Yeah they do, and they should be in place to where you can just clip them back up when reconnecting the harness... how can you mix em up?
87mgte
87 Turbo Targa
Sep 9, 2007
536
Sequim
bridg3r;972639 said:
they come out of my harness in pairs of 2 except for the 2 in front
Go from the back of the engine forward and line up the pairs to where they'll plug in correctly from cylinder 6 forward. You should be able to see (even though they're in pairs) which clip goes to which injector.
bridg3r
50
Holland,MI
starting from the firewall does the injetor wire brown go first or the white and does it go in a pattern like w b w b w b or b w b w b w and one more questin for the cam postioning sensor how do i ajusted it thanks for all your help
