Help!!!!!!!!!!!
865whitemk3
9
i have an 86.5 and it has a hard time starting when it is cold. i bought a new tps today. no luck. it cranks and runs great when the engine is cold, or the outside temperature is less than 60 degrees it gives me a hard time. Please help me, I am, getting frustrated wht this car. I love it but im getting tired of its b.s. as long as the engine is warm it will crank.
daneyan
441
South Florida
maybe your thermostat might be stuck. go to the autoparts store and get a new one and put it in. That should solve your problem.
supra90mkiii
227
Racine, WI
I don't think that would help at all... but i don't have any other suggestions really... check your timing? spark plug gap?....not sure though.
lewis87t
10
maryland
Try turning off all accessories when starting the car. (ac, heat, radio, headlights etc..) See if that helps.
It could be an electrical type issue...battery or alternator perhaps.
Also on a separate occasion try leaving your headlights on for a few minutes before you start your car. Turn them off, then start up the car. This is supposed to be a good way to warm up tired batteries unless I am mistaken. If you notice a difference, that could be it.
There is also a cold start injector on supras that some people take off completely, since its not really neccessary in certain climates, and even in cold climates the car still starts pretty decent without it. You could check and replace that, but I have no experience with them so I dont know.
Also another problem I once had that was similar..
Check your fuel cap/fuel evap charcoal canister system. I don't really know if it is your problem, but it used to be where if I loosened the gas cap before I started it and hear air suck in or out, then leave it loose until the car was started... the car would start fine... That used to happen before on another car I had, not really sure what exactly was going on, but hey its something to try.
Other than that... I did have another problem similar to this before, where if I let the car sit overnight it would not want to start back up easily. It led me to believe that it was only when the car was cold, but it was infact only because I had let the car sit. It had a minor blown headgasket, and when the car sat, it would slowly leak coolant into the cylinders...then when you went to start it, it would sputter or stall, not really want to start.. and puff some white smoke out the back, then be fine. I really doubt thats your problem, but its one more possible cause.
either way good luck, let us know if you figure it out.
robeats91t
237lbs. of Ballast
Jun 4, 2005
210
Tampa, FL
I had a similar problem on my '91...
On the thermostat housing, there are several temperature sensors...one of them is a cold start timer switch (I believe that's the name) that controls the timing during cold starts. Mine was broken by the shop that hot tanked my head, and I didn't realize it until I was trying to start it...I would have to play with the timing just to get it to start, then once it was warm I'd have to adjust it back to 10-12 degrees...
My guess is that that sensor is bad/broken. It is mounted horizontally on the passenger side. Check and make sure the resistance value is within the spec, and make sure the connectors and wires in that area are in good shape.
Once I replaced the sensor, my car starts right up every time, hot or cold.
