help!!??
aznboik1mva
328
Manchester,Ct
hey sp. ive notice that my mk3 turbo has been goin thru fluid lik i go thru tacos:biglaugh:. ive been jus dumping water in it for now.so anyway popped the hood and started looking around. when i got to where the radiator hose connects 2 the thermostat i noticed that there was alot uf pressure in that specific hose. so i changed the thermostat with a brand new one and have been drivnig for a week or so then 2day the car overheated:cry: so i checked the same hose and again alot uf pressure... any ideas?
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
Does it sound like there's a waterfall in the dash sometimes? Any smoke from the exhaust?
aznboik1mva
328
Manchester,Ct
no smoke and no water inside, i think maybe the hose that goes back to the radiator is bad, right now i dont have a jack so i cant really see where the leak is from but its around that area
aznboik1mva
328
Manchester,Ct
Would a clog radiator cause this? And i dont think its a bhg, theres no coolant in oil and vise versa. And its a 2 hks metal head gasket torque to bout 80
soc chaos
Oklahoma
Your top radiator hose should be pressurized. Do you know roughly where the leak is at? There are a bunch of reasons as to why it would overheat need more info
whats with the waterfall thing CRE? Mine does that from time to time granted I am fairly sure its the hose I had to re route from the passenger side to the driver side
Cooling system is pressurized...
Find the leak. This includes doing a test to check for exhaust gasses in the coolant.
CRE
Oct 24, 2005
3,485
Denver, CO
Air... either from a leak or from dumping combustion chamber gasses into the cooling system.
