u didnt unplug the sensor did you?Its next to the strut tower.Has a vac and wires going to it.The gauge is the stock one i assume.Is it reading 0 like its off? or not moving at all?
that's just odd. are you POSITIVE you didnt bump the sensor? what vacuum line did you use for the AFPR? it's very possible that you knocked off the vacuum line going to the boost pressure sensor...
Only vac line I touched was the one to stock fpr.That is the line I used for adj fuel press reg also ? I have a auto meter boost guage just waiting on the pod for it!
Shaeff, thanks for the help car runs great now! I wish I knew what I did to boost guage? I had the batt dissconected? I hooked up a temp set up with the auto meter guage, looks like shit but at least I know how much boost!
