Help wont rev past 2k and no codes?
NYsBlueMA
Evo+supra=3 cars
Sep 24, 2009
136
New York, New York, United States
I just recently did my 1J swap and blew my TPS a few days after I bought one off a running 1 J and now I cant rev past 2000 rpm I have no codes and I dont even think I even set the sensor right isnt it suppose to go in the same direction as the throttle fork?
aphxero
787
Seattle, WA
Probably Idl circuit. Sometimes the jz tps have the wires reversed. I think it's a year/model thing and I've seen it a lot between 1j/2j. Did you buy a 2j tps? If so it's an easy fix with a wire pick.
verify circuits mkay?
NYsBlueMA
Evo+supra=3 cars
Sep 24, 2009
136
found the problem apparently my tps and few others out there are reversed. As mine goes counter clockwise and the traction controlled model came clockwise im trying to see if I find another one or order through toyota. Its hilarious the honda guys around the way thought i was putting in a 2-step
GN_Convert
69
Florida
I am having the same problem. My Apexi AVC shows the throttle position correctly though. I called Aaron at Driftomotion, he said the correct part number is 89452-22080. I have 89452-30150. Does anyone know if it can be rewired, or do I need to get a new TPS?
GN_Convert
69
Florida
I just got a new TPS, Autozone did not have the toyota part, but they had a Duralast one with a 2 year warranty for $92. part number is TPS481 if anyone is interested.
it works great now, I just have to replace my radiator now, the fan hit the shroud and threw a piece into the radiator.
