Help with wiring connectors
BigKO
326
Riverside
Ok everybody,
I have two questions regarding electrical connectors. The problem is that I can't find waht they hook up to! lol :1zhelp:
One iis this connector located next to the igniter, yet i cannot seem to find its connection... The other is a connector that is next to my power steering reservoir, and comes off of the main wiring loom.
I have provided pictures of both... Explanations or pics of where they go would be excellent, and thanks in advance for the help
adampecush
Regular Supramaniac
May 11, 2006
2,118
Edmonton
BigKO;1318972 said:
Ok everybody,
here's what you're missing near the igniter, which i believe is the headlight cleaner control relay:
edit: not so sure where the 2-prong plug goes.
BigKO
326
Riverside
oh ok, so if it truly is the headlight controller relay(which I hope you are right), then this would go unused on my car correct? I am basing this assumption on the fact that I have a 91 and 91's dont have headlight sprayers.. Sound right?
BigKO
326
Riverside
Mk3runner;1319000 said:
I got same connector sitting there. Unused in my book
You are talking about the on on the igniter side correct? Any clue about the 2 pin one on turbo side?
Mk3runner
2,033
Nor Cal
yea.. The one on turbo side, I wanna say it goes to ps.. Maybe I'm wrong. But I know which one your talking about.. Just forgot where it went. Is your harness damaged, or just sorting it?
BigKO
326
Riverside
No, not damaged just sorting it out, I just put my motor in after HG fix and these are the only two connectors unhooked and I am trying to sort out where they go... Your last post was confusing though... Which connector on your car is not used? and by the Power steering do you mean the rack? or the pump itself, because I did not see any connectors on the pump... That was my first thought as well
Mk3runner
2,033
Nor Cal
The one near the ignitor should be unused. That two pin one tho.. Look on the engine bay wall near the afm.. It should be hanging there.
BigKO
326
Riverside
oh ok, Thanks for the help both of you... I dont have time to check it now but first thing in the morning I will...
