What does it mean when your itake system whistles when your turbo starts spooling (gradually louder) and then chirps so to speek when you let off? My engine is completely stock with no aftermarket BOV.
Thanks
Thanks
DigityD'87;1111687 said:What does it mean when your itake system whistles when your turbo starts spooling (gradually louder) and then chirps so to speek when you let off? My engine is completely stock with no aftermarket BOV.
Thanks
TooRandom;1112004 said:cause that happened to my mr2 when i had a hole in my intake. it whistled when i gunned it and it sounded like it was turbo
Rennat;1111789 said:that 'whistle' could just be the turbo sucking air in... but i would check it for shaft play as its probably hitting the compressor housing on the inside.
is it more of a 'super-charger' whine... or is it like a constant 'whooooooooooo' sound?
that chirp should be your bov...
grimreaper;1112136 said:temp guage moving? you checked your coolant level?
grimreaper;1112450 said:^^^ nothing, except if he's giving info that might be related to another issue. temp gauge moving up and down is NOT normal, hence another issue how ever small or large it may be
