Help With VPC installation
empera
Authorized Vendor
Philly.
ok so i just finnished installin the vpc, sensors and all, plugged battery back in....go to start the car, it starts and then it stalls out....
Anyone know wat possibly could be wrong?
empera
Authorized Vendor
Philly.
checked all the connections, the vpc lights up and wat not...i reseted the ECU and now its idleing really really really rough...
88targarose
Got Boredom?
Apr 7, 2005
Albuq, NM
www.turboninjas.com
Ok, so.. you've got an '87.
I don't know a thing about your setup.
Are you using an HKS Harness? If not did you hardwire it? Did you use resistors? Did you unplug the stock AFM? Do you have the right ROM (440cc = SUP011N / 550 = SUP009B)? Are your sensors plugged in to the main box? Does changing the idle knob actually change your idle?
When my car starts from cold, it's finicky and obnoxious for the first 45secs or so. I just finished my VPC Hardwire with the factory 440 ROM.
empera
Authorized Vendor
Philly.
using the correct hks wire harness, removed stock afm, used the right ROM (440), sensors are plugged to they're corresponding harness, idle knob did change the idel but not by much, noticable difference but still not drivable.
empera
Authorized Vendor
Philly.
appearantly i have a bad pressure sensor. Had someone check the sensor on they're setup and got the same results.
