so im going NA-T and i need a little help in figuring were to run the turbo oil inlet from. I know some people run it from were the oilpressure senor is. but that tap is much smalller then the gte oil outlet. so i was thinking i could run the turbo oil inlet line from my oil filter relocation kit. the side of it is tapped for some reason and originally i was just going to plug it but now it might be a good place to run the turbo oil inlet. the the thread fits a 3/8 bolt which is nearly twice as big as the oilpressure senor. so i guess my question is will there be enough oil pressure to send suffiecent amount of oil to the turbo?
