Help with timing?
johnathan1
Supra =
Aug 19, 2005
5,056
Okay, so as most of you know, I am replacing my headgasket... so my question is, how do I make sure the timing is right?? I turned the crank and set it to 0, then I lined up the cam marks. Lined up the dots on the the CPS, and put it straight in carefully, without moving it at all, and it went straight in...
Did I do this right? What should I do?
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
Not familiar with timing lights? They are a strobe that you connect to the number 1 plug wire, then aim at the front main pulley. Fire up the car, jumper the diag block, and adjust the CPS until you get 10-12 degrees on the main pulley at every flash of the strobe...
Sounds complex, but it's really not. Hopefully someone in the SoCal crew can lend you some experience, once you've seen it done once, you'll be able to do it in your sleep.
shaeff
Kurt is FTMFW x2!!!!
11
Around
a hint: use the #6 spark plug wire instead of the #1, its way easier to reach, and will give you the same results when timing. ;)
-shaeff
