:aigo: What is the best timing setting for an automatic turbo? The book says 10-degrees, but im sure someone knows better!:aigo:
Hey thanks!! You do not think the piston will "knock" when I add boost?:icon_razzSuprastic said:The book say 10 degrees, but you can go to 12 degrees for a bit of added power
raymi said::aigo: What is the best timing setting for an automatic turbo? The book says 10-degrees, but im sure someone knows better!:aigo:
Suprastic said:For NA's I think you can go to 12* or 13* BTDC max. I'm currently running 12* on my NA and have had no problems for the past 2 years.
staticpat said:I bumped my timing up to 12 on my na supra and ran premium gas. I put it back to 10 and ran 87 octane. The car actually ran better on the 87, better timeslips too, not worth the cost of increase in gas imo.
jetjock said:Why would someone know better than the engineers who designed the engine?
Set it at 10 btdc with the diag block shorted and be happy.
is yours an automatic???:1zhelp:PorterzSupra said:I ran mine 13 deg, 93 octain 18 PSI no knock, ran great! from 10 to 13 made a noticable power difference!!
And how is it running now?PorterzSupra said:I ran mine 13 deg, 93 octain 18 PSI no knock, ran great! from 10 to 13 made a noticable power difference!!
