Help with the plugs for 1jz swap for early 89 7mgte
vIetDrIfTeR
134
d town
i have early 89 7mgte
okay im slicing IH2 into B3 ma71 89gte harness but im not sure if this is the B3 can some on tell me if this the right diagram for it http://1jz.com/tech/docs/wiring/IH2(87-89).pdf
this plug doesnt look like the one in this diagram but close
and this diagram says plug IH2 connection 18 says goes into plug B1 connection 13.
But 1H1 already has it connection number 11 going into plug B1 connection 13
http://1jz.com/tech/docs/wiring/IH1(87-89).pdf
which is it ??
1James
Lurker
Mar 19, 2009
60
Bay Area, CA
This appears to be B2
1. ABS plug on harness to transmission ----------------- YELLOW
2. ABS plug on harness to transmission --------------------- BLACK
3. ABS plug on harness to transmission-------------------- Red \ Black
Source: http://92tealsupra.webs.com/88turbomtwiring.htm
This is the personal website of 92TealSupra on here.
As you can see there should only be three pins on that plug stock.
vIetDrIfTeR
134
d town
well my car is a original automatic and u can see there more than 3 wires in this plug. Is IH2 suppose to go in B2 because im pretty sure this plug is for the abs but not 100% positive.
