help with taking off the steering wheel
trd3298
19
los angeles
so im taking off the steering wheel to put on my new nrg setup i removed the casing around behind the wheel took off the center of the wheel and removed the center bolt but every time i pull on the steering wheel to take it off the whole column comes at me dont know if this is normal and idk what im missing did i not take off another important bolt please help heres a link to a vid so you can see what happens sorry for the cell phone quality
http://s430.photobucket.com/albums/qq25/awesomeluis/?action=view&current=supraa.mp4
trd3298
19
los angeles
i did i got the steering wheel off now i havee another question for anybody whos dont the nrg setup there are wired with ring that get 'in the way do i just cit the wires?? didnt really want to do that is there another way i saw no clip that connected the wires heres photos any sugestions??
destrux
1,183
10
PA
You need to upload pictures big enough to see. Those are tiny. If you're using a cell phone, turn the camera quality to max and don't use zoom. Then use photobucket to upload them. If you have a smartphone they even have an app.
Maybe post some pictures of the hub kit you got too, so we can see what you're trying to connect.
Your going to need that piece there if you want cruise/horn to work. Have to trim the connector so the hub fits and then run the horn wires through the hub.
Stu_22
124
England
I've just fitted a nrg hub and quick release
I left the ring but cut the connector back and just left the single pin for the horn(ditched cruise cont)
The only problem I have is the hub is too big for the plastic steering column/hub surround I've started filing it out but I thing it's just too big for that
