ok i got my 89 supra and when its cold its fine but after warm up the gas pedal has to be pressed halfway or more to rev up. what causes this? any ideas
the pedal feels good no binding or tension and the tb is opening all the way. and the car is stoke but ive spaced the wastegate to up the boost. but it done this b4 i spaced it.
You're in the wrong section if you're talking about wastegate stuff. What happened before this? Did you do any mods? Check all your vac lines. Does it hesitate? Be more specific.
vac lines are all hooked up. no mods to the car. when the car is cold it dosent do the problem after it comes to temp its like when ur driving you will have to be more than half throttle to rev up other wise it boggs.
