help with r154 tranny removal
bobpogoman
213
Quebec, Canada
im trying to remove my r154 tranny :evil2: and we got some problem.... how the HELL you remove that fork?? lol we remover all bell housing bolt before trying to remove the fork...we must re-put them back before removing the fork?? thx guyes
reply fast im like doing it right now...i got my hands full of shit
Racefiend
OH, YEAAHH!
Apr 6, 2005
106
Bay Area, CA
you can also remove the access plate on the other side of the bell housing, unbolt the pressure plate from the flywheel, and pull the tranny with the clutch attached.
Joel W.
Just A Jedi
Nov 7, 2005
1,561
Washington
I popped off the C clip, that held the pin, that keeps the fork in place.
If I was doing it again, I would try Racefiends way because you don't have to pull the tranny so far back to clear the throw out bearing.
bobpogoman
213
Quebec, Canada
both acces plate are removed..we just removed that clutch fork..lol now we removed all the 6 bolt on the clutch cover...but after??? it still wont come out and we cant remove that cover
NATAN666
yarrrrr
Apr 4, 2005
289
BC
user.dccnet.com
Allan_MA70 said:
dont forget to pull the starter motor :p
that might be it. theres actually 10 bolts to remove not 8 around the bellhousing. once you got those ten bolts and all the pressure plate bolts just pry, shake rattle and pull
