HELP WITH OLD SCHOOL GREDDY PROFEC B
PQSTYLE
PQ
Ok so me and my friend got the old school profec b, and we hooked every thing up and its still not workin. Dose any one have this in there car and can tell me exactly how theres is hooked up and what the switches are set to on the back? Thanks alot its on a stock 7mgte.
MDCmotorsports
Indy 500
www.MDCmotorsports.com
In order to lean, the profec B MUST HAVE EACH LINE HOOKED DIRECTLY TO WHERE THE MANUAL SAYS TO HAVE THEM.
IIRC, One line must be dedicated to the wastegate, one dedicated to the BOV (or any where after the throttle body) and one on the compressor housing (any where BEFORE the throttle body).
Fletch124
2jz swapped!
Jul 17, 2005
1,282
Reno, Nevada
Make sure you have a good power source. I've done it before installing fans, some audio site had info on what the different wires were, well one of the ignition wires(black and yellow) that i wired too was only pushing .2V while the black and orange wire was pushing a good 12V. So just check your wiring, check your ground.
PQSTYLE
PQ
Im sure the wiring is good.
I do have the vac line from the back of the controller hooked up befor the tb. So i will hook that up to the bov vac and see if that works.
