Help with boost gauge.
Mr.PFloyd
I am the Super Devil
Jun 22, 2005
3,964
Mississauga, Ontario
before i got the car to a mechanic, the boost gause wasnt working. The turbo spun and you cou8ld hear it but the gauge wasnt working. Anyone know what can the cause be? i will have the car back this thursday with an entirely new brake system (yes ebrake too :D) and i would want to know what could the problem be.
supraman7mgte
Shut up,bitch!!
Sunny California
try checking the connection at the sending unit on the drivers side fender. it is to the rear or close to the engine bay firewall next to the cruise control thing. it might be bad,or you might have a vacume leak there.the sender is plainly marked,just look and see
Mr.PFloyd
Jun 22, 2005
3,964
YourHondaSux said:
the problem is...its a stock boost gauge. Just spend 40 more bucks on a good aftermarket one. You gotta replace that stock P.O.S anyway.
heh did anyone do a writeup on this :naughty: i need help :(. also what is everyone else running in the stock location.
lagged
1991 1JZ
new rochelle
fixing it could be easy. maybe the sender is unplugged or the vacuum line to it is capped off for whatever reason.
