Alright i brought a Apexi turbo timer so time ago and instilled it and everything worked fine until one day i had the cd player out and the harness was cut (previous owner cut it not me) I accidentally had the cut cd player harness touch each other and blow one of my fuse under the hood. I couldn't even start my car until it was replace, i believe it was a 30 AMP fuse.
To make the long story short after that my turbo timer would not do it's count down to auto shut off, but everything works like my O2 and volt. Now can someone help me with this headache. Thank you in a advance.
Oh, i don't have the plug and play harness for the timer i didn't the cheap way "slice and dice." And yes, nothing happen to the wires, still the same as it was working b4.
