i don't know how to change an alternator, cuz i don't have my manual, and im not that smart about changing car parts, so can somebody please give me instructions on how to change an alternator or take one out? thank you.
Enraged said:unplug the alternator, release tension on the belt (small nut underneath the alternator), unbolt the alt from the lift bracket (on the top) and the tensioner (on the bottom, by the small nut). very simple, you will need 10mm, 12mm, and 14mm wrenches and sockets i think. its pretty simple.
CRE said:Easier than changing a tire... fewer bolts.
Removal:
http://www.cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?S=CH&P=7
Install:
http://www.cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?S=CH&P=17
